I am running 3.7 and new to PC Dmis. My problem is every time I set the correct file location for the .pdf or .rtf file in the edit window print setup and then create a new marked set the file location stays pointed at the same location that the pcdmis program files are saved. No matter what location I change it to the marked set defaults to the same location. Is there a place to change the default path for printing in marked sets. Please help.
Marked Sets .pdf/.rtf problem
by N3WPVI am trying to use marked sets for the first time. My program runs fine but I'm having a problem with printing. I have two print commands in my program...
07-12-2013, 08:40 AM -
by enviroCan someone let me in on a good procedure for creating Marked Sets? I do not know how to mark a set after reading the help (F1) it only left me wiyhout...
11-14-2008, 09:30 AM -
by B. JacobsI am new to this one. I just created a Marked Set in a program I am running that will measure just some holes. I got it to work fine. The problem is that...
04-12-2007, 11:46 AM -
I use Marked Sets all the time; various operations checking different features or having different (in-process) tolerances and have never had this issue......
04-06-2010, 04:29 PM -
by Robert.NyproI have problem with size of Marked Sets?
When opening program always the window is BIG and in the same position . Even if I change this for small...-
02-02-2010, 09:04 AM -
