Program dies at first dimension
  • Program dies at first dimension
    I made an off-line program.
    Ran it off-line.
    execution hangs.
    I cancel, find it stopped at the first dimension in the program.
    If I place the cursor higher in the program and hit CTRL-U.
    Execution resumes and program does not stop where it had earlier.
    This has happened now with two different programs.
    Is very consistant (today at least).
    Any ideas?
    What version are you using?
      Got some code? At least up to the neighborhood it hangs up. I had this happen when using viewsets. Got a solution if that is it (don't use them)
      Craig
        Have you tried clicking on "STOP" then "CONTINUE" in the execute pop-up window?
          V3.7 MR-2 - Windows XP Pro.
          I don't use view sets, had a long time ago, none in this program.
          Yes, I had tried stop and continue, it did not help, had to cancel.
            Wrong Dimenstioning,
            See if you have Dimenstioned the wrong Number , when you dimenstion the feature, you wanted to dimenstion feature or (point 50 ) but you put it under feature point 49 , thiscause most of the times machine to stop execution.
            A Disho
              Sounds like your program is waiting on a command - Maybe some incomplete code? I'd try re-writing the section it hangs up on from scratch and not copy and paste.
                Don't got an infinite loop in there somewhere do ya?
