Error: No error occurred
  • Error: No error occurred
    I opened a program, worked on it off-line, went to save, got "PC-DMIS Message" panel:
    Current Dir\<file name>.PRG:Serialization error. - Error: No error occurred.
    It does not seem to be a permission problem
    Almost looks as though th file name is being interpreted as a directory.
    I got the error a number of times yesterday, have not seen it today.
    Could it be a network problem? - network seemed OK.
    Any ideas?
    I run my programs off the local drive and back them up on the network drive.
      Check the program properties in windows explorer. The file may be set to Read Only.
      sigpic GO LEAFS GO!!!
      Stay true to your friends, 'cause they'll save you in the end.
      -Sam Roberts
