I down loaded 3.7 MR3. I started writing a new program to try it out. When I tried to run the porgram I got a error message that the machine was out of tolerance. I shut it down and rebooted the cmm. It worked that time. I wrote another program which I had the same error, but rebooting did not help. I went back to 3.7 MR2 and have had no problems. Is there a problem with 3.7 mr3?
3.7 MR3 machine error
What version did you upgrade from?
did you update the interfac.dll file? (Maybe that happens automatically - I know the sheffields need a little manual tweaking during upgrades sometimes)
We have a B&S Status with a PH10MQ with a TP20.
The error is telling me the machine is out of tolerance. I pulled in a program from 3.7 mr2 and it ran ok, with no errors. I usually turn on clearplane after I hit the DCC icon. Does that make a difference? The alignment is very simple one: plane, point, line. The surface of the plane is not level it varies in height. Will that make a diffence? I did the same alignment in MR2 with no problem.
by Mike BoeroOne of our plants just upgraded to 3.7 Mr3 from 3.5. Now they say when running old programs the programs will run half way through and stop running and...
09-12-2011, 12:22 PM -
by vajncWe have installed PC-dmis 3.7, on new workstation with xp 64, but program is not working properly as it should. Occasionally it crushes. Before we had...
01-22-2010, 05:38 AM -
by humpdogg369Running Pc-DMIC 3.7 MR 2 and having an error prompt up. It reads The instruction at "0X5F801088 refernced memory at 0X00000004" The memory could...
01-24-2008, 03:27 PM -
by R.AlwardI have 3.7 MR2. I had to update from MR1 just to get my dimensions to work correctly. How is MR3. Does it have more bugs or less. Is it worth upgrading...
04-06-2006, 03:54 PM -
by why meRight now I'm using PCDMIS CAD++ 3.7 MR3 Brown and sharp Global Image machine. I was wondering if it would be beneficiary to upgrade. What are the pros...
01-05-2009, 08:25 AM -
