True Position Repeatability
  • True Position Repeatability
    There's a bore that I measured (offline to online) and I can only hit it 50% of the circumference due to the complexity of the part. When I get the true position of it we found it within the 0.005" call-out (actual 0.003")and we almost accepted the part as good. We used the other cmm and gave us more than the limit (0.007").
    Now we did a repeatability on both machines using 4 different angles and giving us a min/max range of up to 3 thou.
    Do you think what causing the non-repeatability problem is because I'm only hitting 50% circumference of the hole or is it a hardware problem (e.g. probehead, tp20, etc.).
    Thanks in advance guys,
    mds
    p.s.
    the cmm that's giving us out-of-spec TP is the older machine. the good result is coming from the newer cmm though the repeatability is not good.
    Yes
      re-calibrate the probe tips, make sure both have same move, hit, speeds.
        How many points do you take? How well are the spaced out? Do you use the cylinder or circle features to evaluate?
          i used a circle feature using 6 hits...no initial hits...i just found out that we're using 2 different tp20 module. one cmm is medium force and the other extended...
            Well, as long as the calibrations of the tips came out correct, that really should NOT make a difference in the results.
