Pattern & Paste with Pattern
  • Pattern & Paste with Pattern
    I'm hoping someone here can help me......I'm running PC-DMIS 4.2 MR1....I'm trying to use the Paste with Pattern feature........I'm checking a part with 10 holes on a bolt cirlce......I measure the first hole feature location when I copy it then "Paste with Pattern" for the other 9 holes it erases or eliminates the first hole checked...........when actually running it on the CMM the program stops in the middle of the first hole I'm checking........Is this a software issue or am I doing something wrong ?...........any help would be appreciated
    B&S Global Performance
    PC-DMIS CAD 4.2 MR1
    Post You'r Code
      What version of software. are you copying and setting at thirty six degree and using 9 for number times to paste.
      3.7 MR4
        I suspect the following is happening:
        You set the pattern.
        You copy the first feature.
        You click paste with pattern.
        What went wrong there is after you copied the feature your cursor was left in the middle of the block of code for the feature, so when you pasted with pattern everything went Kablooey. (Yep, that is the technical term.)
        To solve this after you copy the feature, click in the edit window below the feature so you cursor is in the clear, then paste with pattern.
        HTH
        Of course this may not be your problem at all, but I have seen this cause headaches and your symptoms fit, so it was worth a shot.
          TRY pasting 10 times might be bug in 4.2.
          3.7 MR4
            He said 4.2 mr1
            Sounds like your pattern is not set-up properly. Go to Edit > Pattern
            Make sure you have the correct angle or offsets for the bolt hole pattern.
            Then Copy the first hole, then past with pattern. Make sure when you copy the first hole you have a clearance plane included in the copy. Otherwise it will only paste the holes without it.
            HTH
              pattern pasting
              I havent had this problem, the only thing that I can think of is that rather than just copying the feature to be pasted with a pattern, you are cutting the feature, then pasting with a pattern.
                WHA????? BIG HELP OHH YEAH
                  THINKING OUTSIDE THE BOX???
                    AGREE
                      I think WES hit it right on the head, I have had this happen also. Make sure cursor is after feature you copied and it will work for you.
                        Thanks for the input........I know I didn't include it in my original posting but I have tried pasting wiith the cursor at the end of the block I copied and I also tried adding a 10 th hole...........Still had the same results
                        PC-DMIS CAD 4.2 MR1
                          Haha Where Do You Get This Pics?
                            Are you sure you don't have the copied feature still highlighted? I've done it myself. It writes right over the hightlighted material.
                              From your girlfriend....Tell her I said hi & not to worry about the change
                              • gage guru
                                paste with pattern
                                by gage guru
                                Ok have 20 holes to measure and want to do paste with pattern. I understand how to do the paste with pattern and it works fine, but I want to make life...
                                05-25-2006, 05:42 PM
                              • swisk212
                                Paste with pattern
                                by swisk212
                                What am I doing wrong ? I have used paste with pattern previously - -pattern and put in offsets and number of times then copy & paste with pattern...
                                11-27-2019, 02:31 PM
                              • Moore Racing
                                Hole pattern
                                by Moore Racing
                                Is there a way to create a hole pattern? I have a part with a 19 hole pattern. Instead of measuring each hole separately. Thank You in advance everyone...
                                07-22-2016, 09:34 AM
                              • BANDY
                                Selecting multiple features
                                by BANDY
                                I need to check 122 same dia holes on part and I wonder how do I select all of them and program this holes. Its kind of a pain doing it one-by-one.
                                09-01-2006, 11:39 AM
                              • mattias
                                paste with pattern crash
                                by mattias
                                I downloaded 2011 version today.PCdmis keep crashing every time I tried to paste with pattern.I had the same problem with 2010 version.I crashes even...
                                04-27-2011, 08:10 PM
