I'm new to using data page and I have found some major weaknesses in this program unless I am doing something wrong. What I am trying to do is statistical analysis on 30 pieces. If found that if you report a feature more than once, it will not put both into Data Page. for example, if you have 2 profile callouts to the same feature, one to the datums and one for form only, Data Page will only record the last of the two reports for profile on that feature. Am I right? I suppose I can create a new feature from the original and report it for the second profile. Another similar situation is if you want to report true position of a hole and also the X and Y position using a +/- tolerance, the X and Y portion of the true position will overwrite the X and Y dimensions previously reported, except without a tolerance which messes up the statistical calculation for each of those dimensions. I found that reversing the order in which I report these (put TP first and then report X and Y) Are there any other weaknesses I need to look out for? I had to run 30 pieces on a long program before discovering these.
PC-DMIS 3.5MR2 Data Page 3.32
