I believe I know this answer already, but is there a way to take a program made in inches and copy\rename\re-(something)\ to make it into metric. I have two parts almost identicle and I already have a program in inches, can I do something to have a copied program but in metric?
PROGRAMS FROM INCHES TO METRIC?
As far as I know there is no way to convert the program to metric. You can change the dimensioning to metric. If you go to the wilcox site, you can download a script that will update all of the tolerances, from metric back to inch at one time. I have it and it works great.Time for the Trolls to leave.
Not Easy, that's for sure
There is definitely no easy way, BUT
A long time ago I wrote a BASIC program to do just that, as an experiment. It simply scaled every hit and every nominal by 25.4. THis is obviously not too bad if all you have is points in the program, but gets ever more complex with planes, lines, ellipses, etc. Back then, it also was easier to create because we had what was called DIMS import. DIMS was like a copy of the edit window in text form.
Anyway, it is probably do-able, but not worthwhile.
Hi Bill,
Version 4 seems pretty cool. It doesn't matter what it is, inch or metric. It may be like your talking about it. I'm not sure, but when I get time, I will check it out. But they did say something about it not mattering if it is inch or metric like it used to be. I just recently installed it, but haven't had time to set it up or program on it yetsigpic
by ClayOgreI have two parts which are virtually identical, except one is metric and one is inch. The inch part is measured with the part oriented a particular way...
01-11-2008, 08:55 AM -
by RplougheIs there a way to have Pc DMIS report out both Metric and Standard Results to a report? The shop I currently work for have a Metric Phobia and the operators...
03-04-2014, 09:27 AM -
by jlefave60Hi,
I'm running ver. 3.5. Is there a way to toggle an existing program between metric and inch without having to rewrite the program?-
02-25-2010, 10:17 AM -
by bertanslowHi folks. Is it possible, if a cmm check has been done in metric, to output the
results in imperial.
Many thanks.
Bert.-
03-11-2008, 12:30 PM -
by EEC1959is there any way to convert an inch program into a metric program without having to go in and switch each characteristic?
01-26-2011, 03:00 PM -
