I measure a lot of holes and core pins in molds. I read once (I believe in this forum) that a CMM is not the best tool for measuring diameters. I have recently had a coworker make the same statement. I use 5,7, or 9 points to measure a hole. I make sure I am measuring in the proper plane. I make sure my setup is correct. When I output the results I make sure to look at roundness error. If a hole or pin is not round then it will probably not check the same dia. with another method (Micrometer or pin gage) as the CMM. I believe PCDMIS uses a best fit method to construct the feature. As long as everyone involved is aware of the limitations of the inspection method I think it works fine. Any and all input or opinions on this are welcome. I often have to defend my machine and methods to the toolmakers that I work with.
Thank You,
JCTB
Thank You,
JCTB
