Can anyone tell me why when I program a part offline everything looks fine and my part is correctly positioned but when I run the program everything works but the points do not fall on the model in the graphics screen. All dimensions come out as expected. I am using an iterative alignment.
Offline to online
Originally posted by rebeldudeDevaney,
are you putting your cursor at the end of the program after running the part to see where points end up?
I am pretty sure I did that. I've been bit by that before.
It's like it's telling me it wants me to put the physical part in the exact location as I have the CAD model in the program. I don't that I need to do the but it's developing all of the measured graphics off of the model and at about the same distance as it looks like I have it on the plateI have not done CAD=Part per the advice of the forum and I am quite happy with everything else.
Originally posted by JohnsonDevaney
I am curious to know when you program offline and use iterate alignments do you, before you run the whole program just mark and run the manual alignment first?
Always wondered about if you have to do that.
If you mark everything for execution it will ask you to manually hit the approximate area of your iterative alignment points before it remeasures each of them in DCC. So I think the answer to your question is no, you don't have to just mark the manual alignment. You can run the whole thing.
Was this what your asking?
If your talking about running it offline. It works the same way only you will be hitting continue to move through your manual hits before it goes into DCC.
Rebeldude,
I removed the machine from my hardware definition and all is lining up well. Do you know if that should matter????
by dwadeStarted a program offline this afternoon and I can't pull points off of CAD model correctly. The points I pull off the model are out in space away from...
11-02-2006, 03:27 PM -
by David WedelOk I have always been able to program part off a model but>>>>always was able to have part so that I could touch off my initial alignment...
03-24-2010, 07:54 AM -
by AuRulesCreated me a generic program yesterday on my offline computer and imported a Catia V5 model w/ ship cordinates. Then for practice I generated a CMM model...
01-03-2007, 07:33 AM -
by JStewartHello all,
We are using PCDmis 2010 MR2, and I have a few questions about programming offline with a CAD model.
1. After...-
10-10-2010, 11:43 AM -
I am programming a Large detailed part OFF-Line without a Model only a Drawing. Very difficult to envision as I go along. Anyone know of a trick or process...
08-14-2008, 10:32 AM -
