When pcdmis goes to update the date base it is updating trying to update all the databases. As far as I can tell it should be only going to the specified one. Help please using 3.5mr2
probly the XSTATS11.tmp file in your main pc-dmis folder. either open it with notepad or wordpad and delete the all the info in it, move it to a different location (it should automatically recreate itself), or rename it like greg said.
Hello,
The only time that this should happen, is when you attempted to send data to an improperly created database. Make sure to check the folder that you are attempting to send the data to and verify that the datapage file is there. Then, you can work with the XSTAT11 file. If you don't fix the root cause, you will fight this battle all day.
As of yesterday at the end of a program where the results update into the Datapage database I get a error. ( Database System Error -127 Database files...
