If that's all the information the drawing gives you, you will most likely need the cad model. Or someone will have to give you xyz coordinates to take your hits, but that too will require Cad.
I might not love my job, but I love the ones it feeds!
If I had to use this drawing, referring to #11, I would consider that the profile of the indicated surface would need to relate to datum A within a tolerance zone of 1 ( inch or millimeter- whichever applies). The drawing section isn't enough to figure out what the target feature is. #9 looks simple enough.
I think I'm in agreement with MATT.
"listening for the last trump... looking toward the eastern sky"
#11 is definately Profile and Location back to Datum -A-. We have this on all of our manifold drawings. Let me ask my GD&T guru about #9 and get back to ya.
*About #11 I agree with Matt it is a slot or gap wit min & max width.
* In order to check the profile for # 9 without cad modle, first, take multiple point for that surface and and construct a PLANE out those point, let us say that surface laying on z plane , then take some indivitual points as measuring points ,and compair them with the original plane you made in z direction , so your measured points should br within -/+0.5 of the z reading of the constructd plane.
I agree with everyone about # 9. Now # 11 is a profile which appears to be on a curved surface and it has the circle around the pointer which means all around. I think you need more of a Datum scheme to check this without cad.
Can some tell me what this means? My OG took the VSP and my NewGuy has a Electronics background. I think it means imperfections less than 3 microns in...
I know its probably possible with variables and arrays......but can somebody point me in the right direction on how to calculate the percentage of in...
My Q.A. Engineer and I are in debate over an issue that has come before all throughout our industry and so I pass it out to all of you yet again. Surface...
