Using 3.7 mr3 with a TP20. I'm starting my program out with a 3mm tip and part way thru the program i switch to a 1mm tip by switching modules with both of them being qualified. The problem is when i switch to the 1mm, my alignment shifts .016. I check my position with the 3mm and is fine. Then check with 1mm and it's always off. Sure could use some help on this one as i've never used multiple tips.
thanks, mike
thanks, mike
