Another Variable Question
  • Another Variable Question
    DIM D15 = 2D DISTANCE FROM PLANE S PLANE TO CIRCLE ITEM19_20A PARALLEL TO ZAXIS, NO_RADIUS UNITS=IN ,$
    M 1.3643 1.3610 0.0100 0.0100 0.0033 0.0000
    DIM D16 = 2D DISTANCE FROM PLANE S PLANE TO CIRCLE ITEM21_22A PARALLEL TO ZAXIS, NO_RADIUS UNITS=IN ,$
    M 1.3627 1.3610 0.0100 0.0100 0.0017 0.0000
    DIM D17 = 2D DISTANCE FROM PLANE S PLANE TO CIRCLE ITEM19_20B PARALLEL TO ZAXIS, NO_RADIUS UNITS=IN ,$
    M 0.3335 0.3310 0.0100 0.0100 0.0025 0.0000
    DIM D18 = 2D DISTANCE FROM PLANE S PLANE TO CIRCLE ITEM21_22B PARALLEL TO ZAXIS, NO_RADIUS UNITS=IN ,$
    M 0.3322 0.3310 0.0100 0.0100 0.0012 0.0000
    now what I need is for pc-dmis to take d15.meas and subtract d17.meas from it and print out the results
    also d16.meas and subtract d18.meas and report it. Thanks in advance!
    XYZ_IJK
    pc-dmis 2012 mr1, 2013mr1
    calypso 5.4 sp1
    Assign/v1 = D15.meas
    Assign/v2 = D17.meas
    Assign/v3 = V1-v2
    Comment/rept,"dim ??? = " +v3
    Kevin
      Or like we discussed in the other thread:
                  COMMENT/REPT,NO,"dim ??? = " D15.M.MEAS - D16.M.MEAS
        Thanks Guys!
        XYZ_IJK
        calypso 5.4 sp1
          Don't forget the M extension. Even if it is a one line dimension you need the axis extension as there is other information in a dimension you can capture.
