I've had that happen a few times before with the autoline in 3.7. It even did it for a B&S application engineer when he was here. Take vector points and then construct a line from the points and remove the autoline from your toolbars.
Dont use autoplane, autoline with 3.7 mr2 or less, these are buggies, now with 3.7 mr3 works well, but I dont see any advantages to use them versus measured plane or line,
autoplane on Version 4.0 works very well since there is a new option to detect holes on the CAD model, hits will be spaced according with CAD
I use autoplane in 3.7MR3 and haven't had any vector problems. The only problem I've had is when moving a program from PC to PC sometimes it will tell me that my autoplane is not a supported feature in current version. I just reconstruct it and go on. I've never had luck with autoline.
I had the vectors changing when I create an "Auto Cirle". In my case this happenned if I accidentally touching the part with the styli while the auto feature dialog box is still open. I have to then reset the vectors to whatever they were.
Ok I have two planes running (somewhat) parallel to each other. I want to create a mid line between them. No problem. The result I get is a line that...
We have a "surprise" glich that we have never seen before. A porgram was created and we are using Surface points with 3 initial hits and 0 Permanent...
I've created a line between two circles to align the x-plus axis on (Dmis doesn't like aligning to a single circle so i find it best to create a line...
