Make an extra alignment using that plane. Translate or move your alignment the direction you want, 31mm. Create a new plane at that alignment. Recall old alignment. New plane is there to be uses. Just an idea.
I'm having trouble with determining the radius of a cylinder cut by 2 non-perpendicular plane, how can I measure it with just only 6 points? I can't discover the mathematical fundamentals of that measurement, anyone can explain me? Thank you!
