distance to edge of a slot
  • distance to edge of a slot
    I have a square slot 3mm x 3mm, It is dimensioned to front edge and back edge of the slot. I am having a huge amount of variation in the slot location so I am having trouble taking a single point or line on the edges. I can measure the slot itself with the help of FIND HOLE. Is there a way to dimension to the front edge and back edge of the slot from the slot feature? I am using a 2mm stylus and could change to a 1mm if I had to, but would rather not due to this being our most commonly used stylus, and I want it to be as easy as possible for the techs.
    I might not love my job, but I love the ones it feeds!
    iI'm not sure but I think you can use distance and add radii. Otherwise use the slt?.hit[?] to dimension it.
      How about use the find hole, then take an edge points and use the slot as your rmeas feature.
        1 thing you could do if find the slot and then set as your zero,zero location and then measure edges......Just a thought.
          Russ,
          Is that dog getting reading to use that chair leg as a fire hydrant?
            Bob, do you know how to rmeas?
              Thanks guys the rmeas worked great
              Originally posted by cmmguy
              Russ,
              He might have been thinking about it, but he knew my wife would kill him so he thought better of it.
