How many of you are required to do a correlation study on your program before accepting final product? This is our procedure, but I question the reasonableness of it.
It basically consists of running the program on a given part. Then either check it on the plate using layout methods or check it manually on a CMM or check it against another CMM program written seperately on another CMM. If the difference between the 2 results are within 10% of the tolerance then all is well. If the difference is between 10% to 20% then you need an explaination. If it is over 20% then you have to figure out why and do another study.
My problem with this is if you are checking a straight diameter, the diffence between the results has more to do with the CMMs than the program. Most of our programs consist of measuring bolt circles, diameters and drop dimensions. There is some compound angles and gage points, but it's not the majority of the dimensions.
We have to do it so I do, but to me it just seems like a big joke, for the most part. I can see double checking the complex alignments and gage points, but not the straight forward stuff.
Does anyone else have an opinion on this?
