Diameter at the end of a radius?
  • Diameter at the end of a radius?
    Help, I have a part that is about 3.5" long (round) with an I.D of 1.5" in diameter. On one end of the I.D. there is a radius of 1.5", there is a diameter called out at the top of the radius. Any suggestions?
    This is what I tried, and did not work - est a plane on top of the part, took as many hits on the radius as possible, then constructed a point at the intersect. Tried doing this in three places and then constructing a circle from the three points. Didn't work, am I going about this with the right approach or is there a better way?
    I love how creative engineers can be some times.
    If I were checking it I'd check the radius at, let's say, eight locations (45 degree spacing) using perhaps an 8-point O.D.. Keep an eye on the form deviation of each radius just to be comfortable with what comes next.
    Orbit the 1.5" bore.
    Take those eight measured circles and construct a diameter through their centerlines, in essence, define the locus of the radius.
    Is that the diameter you speak of ? I just did this same thing (again) on a part a last week.
      Use an optical comparator...
        I assumed it was a radius at the 1.5 I.D.
        If it's on the outside, a comparator would be what I'd use.
          It is an inside radius in the ID
            Then, like I said.
            • AuRules
              Checking Radius
              by AuRules
              Got a tricky one fellows, how would you go about checking these 2 radius I have pictured in the attachment I need size and location. The bottom part of...
              09-12-2013, 01:11 PM
            • AuRules
              Radius Help
              by AuRules
              I was just handed a new part a few minutes ago from our ME. The part is a cap for the end of a composite propeller. Programmed one just like this before...
              07-18-2013, 03:53 PM
            • AuRules
              Radius TP
              by AuRules
              I noticed that you cannot use a radius in a TP callout just the diameter. Where having a argument with the operator that his part is good because were...
              03-12-2009, 03:00 PM
            • dennisgilpin
              Measuring a 1mm radius
              by dennisgilpin
              Hi there, I'm trying to find out what is the best way to measure this 1mm radius on the side of my part. I'm using a .5mmx20 probe, taking 8 hits on radius....
              03-05-2013, 10:43 AM
            • Buckeye
              Find radius with Auto Feature circle
              by Buckeye
              I am not having much luck finding help on this, so I will start a new thread. I am measuring a diesel crankshaft, and need to find the tangency point...
              05-07-2008, 03:16 PM
