TP gone haywire!
  • TP gone haywire!
    Ever get this sort of thing?
    Any ideas?
    Solved, just shout the system down and rebooted all is good again
                COMMENT/REPT,################################ ITEM #9 [HOLE #102-110] TP
    DIM LOC20= TRUE POSITION OF CIRCLE CIR40  UNITS=MM ,$
    GRAPH=OFF  TEXT=OFF  MULT=10.00  OUTPUT=BOTH  FIT TO DATUMS=OFF  DEV PERPEN CENTERLINE=ON  DISPLAY=DIAMETER
    AX       MEAS    NOMINAL       +TOL       -TOL      BONUS        DEV     OUTTOL
    Y    -61.2843   -61.2800                                     -0.0043
    Z     14.3729    14.3500                                      0.0229
    DF    13.5636    13.5450     0.2500     0.2500                0.0186     0.0000 ----#----
    TP                   RFS     0.5000                0.0000     0.9694     0.4694 -------->
    END OF DIMENSION LOC20
    DIM LOC21= TRUE POSITION OF CIRCLE CIR41  UNITS=MM ,$
    Y   -137.4003  -137.4600                                      0.0597
    Z     95.1283    95.1200                                      0.0083
    DF    13.5589    13.5000     0.2500     0.2500                0.0589     0.0000 -----#---
    TP                   RFS     0.5000                0.0000     2.5586     2.0586 -------->
    END OF DIMENSION LOC21
    DIM LOC22= TRUE POSITION OF CIRCLE CIR42  UNITS=MM ,$
    Y   -137.3113  -137.4600                                      0.1487
    Z    292.1857   292.2200                                     -0.0343
    DF    13.6296    13.5000     0.2500     0.2500                0.1296     0.0000 ------#--
    TP                   RFS     0.5000                0.0000     5.3795     4.8795 -------->
    END OF DIMENSION LOC22
    DIM LOC23= TRUE POSITION OF CIRCLE CIR43  UNITS=MM ,$
    Y    -61.2380   -61.2800                                      0.0420
    Z    372.9746   372.9900                                     -0.0154
    DF    13.5722    13.5000     0.2500     0.2500                0.0722     0.0000 -----#---
    TP                   RFS     0.5000                0.0000     0.1084     0.0000 -#-------
    END OF DIMENSION LOC23
    DIM LOC24= TRUE POSITION OF CIRCLE CIR31  UNITS=MM ,$
    Y    220.9468   220.9400                                      0.0068
    Z    275.9050   275.8700                                      0.0350
    TP                   RFS     0.5000                0.0000     5.2589     4.7589 -------->
    END OF DIMENSION LOC24
    DIM LOC25= TRUE POSITION OF CIRCLE CIR33  UNITS=MM ,$
    Y    220.9359   220.9400                                     -0.0041
    Z    111.5143   111.4700                                      0.0443
    DF    13.5368    13.5000     0.2500     0.2500                0.0368     0.0000 -----#---
    TP                   RFS     0.5000                0.0000     2.6620     2.1620 -------->
    END OF DIMENSION LOC25
    DIM LOC26= TRUE POSITION OF CIRCLE CIR35  UNITS=MM ,$
    Y    148.0111   148.0300                                     -0.0189
    Z     32.4190    32.3600                                      0.0590
    DF    13.5619    13.5000     0.2500     0.2500                0.0619     0.0000 -----#---
    TP                   RFS     0.5000                0.0000     1.8074     1.3074 -------->
    END OF DIMENSION LOC26
    DIM LOC27= TRUE POSITION OF CIRCLE CIR36  UNITS=MM ,$
    Y    127.7381   127.7900                                     -0.0519
    Z    -14.4263   -14.5400                                      0.1137
    DF    13.6077    13.5000     0.2500     0.2500                0.1077     0.0000 ------#--
    TP                   RFS     0.5000                0.0000     3.3463     2.8463 -------->
    END OF DIMENSION LOC27
    DIM LOC28= TRUE POSITION OF CIRCLE CIR37  UNITS=MM ,$
    Y     52.6919    52.7300                                     -0.0381
    Z    -35.7228   -35.8600                                      0.1372
    DF    13.6349    13.5000     0.2500     0.2500                0.1349     0.0000 ------#--
    TP                   RFS     0.5000                0.0000     5.7499     5.2499 -------->
    END OF DIMENSION LOC28
    Any ideas?
    Well, now I can read it, at least
      Well, here are some questions:
      1) Is this a new program or an old one that just went whack-o?
      2) Are you using the correct report axis for the holes? I am NOT sure what the PERP-To-CENTER LINE will do if you are reporting the WRONG axis as the individual axis, will it still use the 'correct' axis in the calculations?
      3) WHY do you have a MULTIPLIER turned on in the dimension?
        1) Old
        2) Yes
        3) No multiplier is turned on.
          Redo each TP after each existing one and see if it reports the same. Sometimes I've seen the Demon get wierd with TPs. The only fix is to delete and redo.
          sigpic GDTPS - 0584
            I did try that and each one then reads correctly. I then did a save on the program and reran the part and the TP's all went off the chart again. I have 20 other holes that I am also doing TP on and they seem to be correct. This one group has a mind of it's own and it just started this morning.
              What kind of alignment is in the program? 3-2-1 or Iterative? Did you use CAD=PART? Are there multiple alignments in the program?
              IS that particular program showing LAST RUN dimensions or are they hold-overs from a previous part? Is your part location between checks that much different? If you save it and re-open it, do the TP values change? Are they showing up in Datapage correctly (if you have it)?
                My head just exploded.
                  In the immortal words of Nancy Reagan "Just say no" (to pcdmis tp callouts)
                  Could just calculate the tp into variables and report them. I know it would take a few minutes but...
                  You have unleashed the fury!!!
                  Global (big) 3.7mr1 SP600
                    Did you try shutting everything down & re-booting. You will probably have to re-dimension them again, but i'm sure everything will work out ok
                    Gotta go its lunch on the titanic now
                      I haven't gone there yet, Guess that sliped my mind. Thank you.
                        PRINT/REPORT,EXEC MODE=END,$
                        TO_FILE=OFF,AUTO=1,$
                        TO_PRINTER=OFF,DRAFTMODE=OFF,$
                        Just throwing this out there to check....One of the BS engineers said make sure this is correct and set to delete _instances or it will throw a monkey wrench in the fire.
                          I looked and mine is set to delete_instances. but Thank you for the input.
                            OK, I see that your TP's are for the Y and the Z elements. Could you be accidentally calculating the X and Y elements for the TP? Usually when I have a strange output like that, it's a simple "GIGO" problem like this.
