3.5mr2
I have taken 2 points and need to construct a line through them, but I keep getting the following error:
CANNOT CONSTRUCT LINE:'BASE_LN'. FEATURES DO NOT INTERSECT/MATH
DOES NOT CONVERGE
I have inserted the code from my program. If anyone has any suggestions I would greatly appreciate the help.
I HAVE TRANSLATED TO THE FIRST POINT, ROTATED NORMAL TO SURFACE
LE_BASE =ALIGNMENT/START,RECALL
_E_EC:as1806, LIST= YES
ALIGNMENT/TRANS_OFFSET,XAXIS,-0.125
ALIGNMENT/TRANS_OFFSET,YAXIS,-0.581
ALIGNMENT/TRANS_OFFSET,ZAXIS,4.932
ALIGNMENT/ROTATE_OFFSET,31.101,ABOUT,ZPLUS
ALIGNMENT/END
I TOOK THE POINT NOMRAL TO SURFACE
LE_BS =AUTO/VECTOR POINT, SHOWALLPARAMS=NO
THEO/0,0,0,-1,0,0
ACTL/-0.0003,-0.0001,0.0001,-1,0,0
TARG/0,0,0,-1,0,0
RECALL/ALIGNMENT,EXTERNAL,as1806,D_E_EC:as1806
MOVE/INCREMENT,-0.5,0,0
MOVE/INCREMENT,0,1,0
I TRANSLATED TO THE 2ND POINT, ROTATED NORMAL TO SURFACE
TE_BASE =ALIGNMENT/START,RECALL
ALIGNMENT/TRANS_OFFSET,XAXIS,0.272
ALIGNMENT/TRANS_OFFSET,YAXIS,0.576
ALIGNMENT/ROTATE_OFFSET,-47.628,ABOUT,ZPLUS
ALIGNMENT/END
TE_BS =AUTO/VECTOR POINT, SHOWALLPARAMS=NO
THEO/0,0,0,-1,0,0
ACTL/0.0008,-0.0003,0.0001,-1,0,0
TARG/0,0,0,-1,0,0
I TRANSLATED TO THE 1ST POINT, AND ROTATED TO THE 2ND POINT
A11 =ALIGNMENT/START,RECALL
ALIGNMENT/TRANS,XAXIS,LE_BS
ALIGNMENT/TRANS,YAXIS,LE_BS
ALIGNMENT/ROTATE_CIRCLE,XPLUS,TO,LE_BS,AND,TE_BS,ABOUT,ZPLUS
ALIGNMENT/END
I TRY TO CREATE A LINE HERE AND IT GIVES ME THE FOLLOWING ERROR
"CANNOT CONSTRUCT LINE:'BASE_LN'. FEATURES DO NOT INTERSECT/MATH
DOES NOT CONVERGE"
BASE_LN =FEAT/LINE,RECT,UNBND
THEO/0,0,0,0.9874393,0.1538118,0.0361325
ACTL/0,0,0.0001,1,0,-0.0000479
CONSTR/LINE,BF,3D,LE_BS,TE_BS,,
Thanks in advance
Teresa
DOES NOT CONVERGE
ALIGNMENT/END
THEO/0,0,0,-1,0,0
TARG/0,0,0,-1,0,0
ALIGNMENT/END
THEO/0,0,0,-1,0,0
TARG/0,0,0,-1,0,0
ALIGNMENT/END
DOES NOT CONVERGE"
Thanks in advance
Teresa
