When PC-Dmis is calculating MMC why is it calculating from the top of the tolerance. I though that it should be applied from the 9.7 not the high limit of 10. Please see attachment. Am I missing something??????
MMC ISSUES
this is what mine does. I have never attached anything so here we goAttached Files
MMC
The calculations are for an outside diameter and not an inside diameter. When you created your diameter from the create circle option, you had the button on "out" and not "in". If you change that , then you will get the good amount of bonus.
With MMC, the larger the hole (inside dia.) the more bonus.
All the best Johnsigpic If only all problems were so simple
Originally posted by Tim NicholsThanks everyone.....when I created the circles at the intersection of a plane and cone...it was creating them as and od not an id....I knew that it had to be something stupid.
Yahoo!
TKsigpicHave a homebrew
by GEllsworthI had a discussion with an engineer that MMC should be used for hole diameters and LMC should be used for stud's or O/D parts. He didnt agree and said...
10-06-2009, 12:57 PM -
by NBO CMMIs there a setting to allow MMC on an ID when the feature is oversize?
02-18-2020, 08:48 AM -
by FutureManIt's been a while, and I don't have a manual handy right now, so I need some help from the GD&T wizzes out there...
I have to measure...-
10-07-2008, 05:14 PM -
by ErikirI have a print that indicates:
diameter 3.4+-.2 thru all
| position | diameter 0 MMC | A | B | C |
I don't understand why there...-
02-15-2013, 06:08 PM -
Does anyone know how to extract the mmc outtol value from a TP dimension?
I use
IF/DIM.TP.OUTTOL > 0
in...-
03-24-2009, 12:09 PM -
