Imagine a flat surface with a round indention in it. The feature looks like a sphere could sit in it. Anyway, the print calls out a radius on it. How would you measure this with a CMM? Can't use sphere? Circle?
Measuring suggestions for this radius
My max radius gage is .5" this is .760". I don't have a way really to cut the thing dead center to get an accurate measurement. So CMM is my best bet.I used to be high on life but I built up a tolerance.
If you have and XYZ location you could translate there and measure radial points and dimension. If you do not have a 1/3 or more of your radius or a wide open tolerance you will have nothing but problems.
BSWindows 7
Pc-Dmis 2015
Global Performance 7-10-7
.761 +/-.005. Sorry too lazy to hook up the digital cam or scanner. The part is a can. On the print it's a cross-section side view and calls out this dimension. The feature is located at the top of the part.I used to be high on life but I built up a tolerance.
What BSchwark said, use an optical comparator. The clay might deform too easily for the tolerance. What we use to do is to make a mold with RTV11 and the cut it with a rasor blade and check it on the comparator. It holds the size very good and does not shrink(we made a mold of a ring gage and checked it with a mike every day for a week and it changed only .0001"). THe other quick method and not as accurate is to use a stick of sealing wax - hold a lighter to it for a couple seconds and then when it is "wet" push it into the radius. Again, check it optically.
by quality2214I currently have (for a lack of better term) bowl shaped cavity that we will be injection molding into. There are no tooling prints for it. The engineering...
11-16-2006, 11:01 AM -
by giantslayerI have a .078 radius that is .040 long. How accurately will the CMM be able to measure that diameter?
12-14-2015, 11:20 AM -
by QA Plant 3From my understanding, when I want to find out the radius on something, I measure a "circle". I have a flat plate that is curved at a radius...
10-07-2010, 03:48 PM -
by d.evansWith only 90 degrees of arc, how accurate should I expect a corner radius measurement to be using my CMM?
I've got a part with a R .250" +.000/-.003"....-
06-16-2006, 10:30 AM -
by Jonathan SI need to measure a dimension to the centerline of a radius, but the radius is 2" and only covers an arc of about 25 degrees. Measured on the optical...
06-01-2006, 10:40 AM -
