Ok Guys I have A Loop,That I'm been Trying to run,But I cant't, I have 108 Holes in Line,the loop pattern hole is 15.88mm center to center then 15.88 & 12.70 mm.then it starts again.I read the manual,but I'm having problems.
The way I'm thinking to do it is,Level,rotate & origen to datums and then origen at the First hole then start the loop.Please advice
ASSIGN/V2 = V1.XYZALIGN2.ORIGIN0
V1 =LOOP/START, ID = YES, NUMBER = 72, START = 5, SKIP = 3,,
OFFSET: XAXIS = 0, YAXIS = 15.88, ZAXIS = -2, ANGLE = 0
LOOP/END
LOOP/END
