I'm using 3.7 MR3. Does anyone know how to adjust the page set-up, because when I print a report it only fills the page 3/4 of the way. I have about of 2 inches of blank paper on the bottom of each page. Thank you.
Printing reports
Did this ever get fixed? Can we adjust the margins somehow? I don't have the time to babysit all three CMMs through the day and convert files so I can use less paper. Also, how do you make the results page print the results at the bottom of the report instead of printing a seperate page?sigpic
There is still no way to 'adjust' how your printout works, unless you are using V4.0 or up, but then you have to make a template to make the report look how you want it to. I have not heard much good about that version yet.sigpic
If you want everything to fit, change the font size or deselect headings etc in the setup menu. Remove anything you don't really need and that should free up space. Unless your printer has built in auto center in the properties/advance tab you can't do notta.I used to be high on life but I built up a tolerance.
That stinks. I see a good 4" wasted on each page. We did get rid of the header a while back and then I had people complain that it was too hard to tell page one at first glance. I put a comment on it that read "Page #1" but that wasn't good enough either. I never put the header back on and the complaining is to a minimum of a couple of people who don't know how to read the darn thing anyway. What is up with the extra page of the number in/out of tolerance? Why on some of my reports will it put it at the bottom of the last tolerance page and others it creates a whole new page? (And the last tolerance page is not full)sigpic
by sealevelI finally have my reports printing with no crappy/unwanted background colors in TEXT ONLY mode. Seems I need to print WITH background colors enabled....
11-19-2008, 08:25 PM -
by Allen LongHow do you set the reports to write the correct page numbers ?
right now it will say 1 of 4 , 2 of 4 ,1 of 1, 3 of 5 help!!!-
12-17-2007, 12:41 PM -
by UnderspecI'm using v3.7 MR3. My reports are coming up short. Each part contains a set of dimensions. At the end of the page I'm missing dimensions that should...
10-19-2006, 12:16 PM -
by Big JohnHello,
What I want to do is to add the page numbers to my report.
I know this has been asked before, but I can't seem to get it right....-
05-11-2017, 05:40 PM -
by Big JohnHallo,
Question: How kan I set up my report printing so that the page numbers are also exported. In PC_Dmis the page numbers are visible,...-
04-03-2012, 11:45 AM -
