Is there a command you can put anywhere in the program to clear everhting out in your report and start over?
CLEAR REPORT COMMAND
If you mean go back to the nominal values yes.
This is a basic script. Just insert in your program(I insert at the end). I think before the insertion you may need to include a print command, otherwise you won't get your measured info. I usually insert this and run it and then delete. But you can leave it in the program.Last edited by JamesMannes; 08-03-2007, 08:27 AM.sigpic
The reason I want to do this is, when I do an alignment, I report how close it is. Sometimes, it will be out of tolerance. I put a Yes/No comment in after it reports the dimensions from the alignment. If it is out of tolerance, I command it to go back and do another alignment, but it keeps the numbers from the first alignment also. I want to have them cleared, then report the new alignment numbers only.sigpic
by enascimentoI´d like to know how I make to inhibit command TIPA0... when I use "IF_GOTO/". Because PC-Dmis executes this command before for then executing...
Channel: PC-DMIS Blade Inspection
07-10-2006, 07:22 PM -
by greeeeHi
Can you tel me why Auto-align YPLUS translated to WALECB(datum B). Shouldn't be YPLUS translated to WALECB PŁC(Datum C)?
Best ...-
05-24-2020, 09:53 AM -
Wondering if it's possible to generate individual reports of multiple parts measured in a looped program?
02-16-2013, 06:23 AM -
by mh1349I have tried to find a forum on this but couldn't. If one is out there already please lead me to it. I want to print a report and have it automatically...
01-21-2013, 01:26 PM -
by Slug DawsonIs there a command that tells the report to print starting on a new page to create breaks in dimensional reports? It would be nice to set a break in...
05-05-2010, 11:23 AM -
