I have to circles,different diameters,same "z","y" axis. I'm trying to get the distance between the bottom of each diameters radius along the "z" axis. Using distance from circle to circle with add or subtract radius doesnt work. I'm looking to use an assignment/variable to give me the distance. Any help? Thanks in advance.
Assignment/ Variable
They are the same on the Y and Z and you are looking for the distance in the Z, I am confused. It sounds like they are in the X workplane no? Am I right in reading that you want to know the difference in where the bottom of the "arc" of each circle is in the Z axis (I don't know if I am conveying this correctly)?<internet bumper sticker goes here>
Create a generic feature (point) and use the V3 as the Z actual. You will have to type in all the nominals and the variable. Just put your cursor at the end of your program, hit ENTER, then type in GENER and it will fill in for you, then you enter the noms, actuals, etc.sigpic
Bayorbear,
You might want to take a look at the "Using Expressions and Variables" section of the help file; it has numerous examples of variable usage.Jared Hess - Techwriter @ WAI
Assignment/Variables
Matt, I tried to do as you suggested with no luck. And the help file gives no example close to what i'm looking for. See my part program:
CIR-1 =AUTO/CIRCLE,SHOWALLPARAMS = YES,SHOWHITS = NO
THEO/-1.29,0,2.282,1,0,0,3.762
ACTL/-1.29,0,2.282,1,0,0,3.762
TARG/-1.29,0,2.282,1,0,0
THEO_THICKNESS = 0,RECT,IN,STRAIGHT,LEAST_SQR,ONERROR = NO,$
AUTO MOVE = NO,DISTANCE = 0.3,RMEAS = None,None,None,$
READ POS = NO,FIND HOLE = NO,REMEASURE = NO,$
NUMHITS = 4,INIT = 0,PERM = 0,SPACER = 0,PITCH = 0,$
START ANG = 20,END ANG = 160,DEPTH = 0,$
ANGLE VEC = 0,-1,0
CIR-2 =FEAT/CIRCLE,RECT,IN,LEAST_SQR
THEO/-2.495,0,2.4411,1,0,0,2.7441
ACTL/-2.495,0,2.4411,1,0,0,2.7441
MEAS/CIRCLE,4,WORKPLANE
HIT/BASIC,NORMAL,-2.495,1.0337,1.5389,0,-0.7534373,0.6575198,-2.495,1.0337,1.5389,USE THEO = YES
HIT/BASIC,NORMAL,-2.495,0.3891,1.1254,0,-0.2836238,0.9589356,-2.495,0.3891,1.1254,USE THEO = YES
HIT/BASIC,NORMAL,-2.495,-0.3767,1.1218,0,0.2745601,0.9615699,-2.495,-0.3767,1.1218,USE THEO = YES
HIT/BASIC,NORMAL,-2.495,-1.0252,1.5292,0,0.7471976,0.6646019,-2.495,-1.0252,1.5292,USE THEO = YES
ENDMEAS/
ASSIGN/V3 = CIR-2.Z-CIR-2.R
ASSIGN/V4 = CIR-1.Z-CIR-1.R
ASSIGN/V5 = V3-V4
F2 =GENERIC/POINT,DEPENDENT,RECT,$
NOM/XYZ,0,0,0,$
MEAS/XYZ,0,0,V5,$
NOM/IJK,0,0,1,$
MEAS/IJK,0,0,1
DIM LOC14= LOCATION OF POINT F2 UNITS=IN ,$
Z 0.0000 0.0150 0.0150 0.0000 0.0000 0.0000 ----#----
END OF DIMENSION LOC14
Some "numbnut" changed cir-2 from an auto-circle, but this is basically it. "F2" equates to zero. Ive tried different ways with no success. Assignments V3 & V4 are "red" so i know somethings not right. Should I be enclosing my assiignments with () , {}, " ", or <>? What I'm looking for is:
cir-1 = 3.762 dia / 2 = 1.881 r (Z) 2.282 - (R) 1.881 = .401
cir-2 = 2.744 dia./2 = 1.372 r (Z) 2.441 - (R) = 1.069
1.069 - .401 = .668 This answer is what I'm trying to show on my report. I'm running ver. 3.6 .
Another question for variable use
I'm not real familiar with the HLL in PC-DMIS but should you not have to assign a variable to each characteristic you want use in the equation?
ASSIGN/V1 = CIR1.Z
ASSIGN/V2 = CIR1.R
ASSIGN/V3 = V1-V2
ASSIGN/V4 = CIR2.Z
ASSIGN/V5 = CIR2.R
ASSIGN/V6 = V4-V5
ASSIGN/V7 = V3-V6Xcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
YOU CAN NOT HAVE A "-" SIGN AS PART OF A FEATURE ID. Pcdmis always sees this as a minus sign in a variable assignment. Now, when you fix the ID's of the features, it will NOT update the assignments, they will have to be changed by hand, each one, it is not like dimensions that automatically update to the new feature ID.sigpic
Ok, here I go with a dumb question....
Why can't you construct a line along the desired axis that is inline with the two diameter's centers. Intersect the line with the radius of each diameter and then do the distance between the two points along the Z axis??
Without a diagram I could only guess. I would use offsets of the radius. This question has been asked before I think.I used to be high on life but I built up a tolerance.
Thanks for all the responses. I am wanting to get into using "assignments" more, but at this, i am willing to try any suggestions. My main concern is using the measured radius along the z axis of each circle. Reason for this is because at the bottom radius of one of the diameters is actually where a Datum is called out, and I need to report the distance between the two. A 2d distance along Z axis. Keeping in mind that the parts may vary in radius size.
by william
I have a question regarding Distance Dimensions with circles using add radius. I have never had an issue with them until now, but for some reason...-
01-19-2015, 07:29 PM -
by DPINEDOLooking for some help with the 1.839/1.849 distance. This callout is not a Cartesian distance . Its asking for the circumference value from point to point....
06-29-2016, 09:44 AM -
I am trying to measure the distance between two half circle nubs on a part. I tried taking a point off the center of the nub but if the probe doesn't...
05-15-2015, 02:11 PM -
by vdrsnk04Well, i have been searching for answers for quite some time now and have got no where fast. Maybe you guys could give me some help. So, i have a part...
11-20-2012, 09:37 AM -
by FAMOUSX1Hello!
Is there a way to dimension the distance between 2 circle minus or plus the radius?
I am trying to dimension the .097-.100.
The...-
07-24-2016, 11:08 AM -
