I calibrated a disk probe(25mm X 2.5) and have a couple of questions.
Can it be used for height as it has near the end of the diameter like a little pin through it that it a little higher than the top and bottom of the disk or do you have to thread a probe into the bottom of it.
If the answer is use another probe - then on the part I am measuring the bottom probe will not allow the disk to get at the diameter to be measured as there is another surface below it that interferes.
Also the calibration I was only off by .001mm on the diameter of the cal sphere and stnd dev was .002. I then checked a ring gage and was off by .020mm and it was done with auto circle after I manually aligned it.
Please help and I will look at posts after my meeting I have to run to.....
Thanks in advance.......
