Using mm4 I would just intersect the plane with the cylinder and get the dimension from the corner of the part. I am not sure what to do with the new machine. I have a cylinder at a 20 degree angle, in a square block. I am having trouble reporting the dimension where the cylinder intersects the plane on the top of the part. Thanks for the help!
intersect cylinder to plane?
by Slug DawsonImagine an empty beer mug lying on it's side. However, the handle of the mug doesn't drive straight toward the center of the mug, it's at a slight angle....
02-05-2010, 02:30 PM -
by DustinWAny thoughts on how to make a tangent plane to a measured cylinder (one created with Auto-Cylinder). I have a constructed plane that the tangent plane...
04-03-2015, 03:08 PM -
Projected Point / Pierce Point
Can someone explain the difference between these two feature types.
I have a straight forward...-
10-22-2009, 08:32 AM -
by williamI'm wondering if there is a way I can construct and callout a line where a cylinder meets a plane. Just for explanation purposes, imagine you sectioned...
01-27-2015, 07:46 PM -
by MarkusI am attempting to dimension the few cylinders on this door that are cut with a 15 degree angle on them and then welded to the bent plate. Previously,...
Channel: PC-DMIS Portable
10-09-2015, 10:23 AM -
