I have a part that looks like a can. It has holes on the sides at set angles from a datum hole (C) which is also on the side. I set [A] as the plane, [B] as the OD, create a line from B to C and rotate accordingly. On top of the part there are holes that are TP to A-B-C using MMC on the feature, -B-, and -C-. When I dimension TP using datums with MMC on the feature, -B-, and -C-, i get out of spec conditions. When I don't use -C- for MMC then it comes into spec. I figure I am safe not using -C- for MMC because I rotate basic to these holes on top anyway. Any ideas?
True Position Again =(
Where is the MMC in the FCF? If it is only on the feature, you shouldn't be using MMC on the datums.
Also, back to my old standby, can you verify it off the CMM (on a plate)? Is it in tolerance there?
What about using the CMM results with standard dimensioning and calculating TP?
Just some thoughts.When in doubt, post code. A second set of eyes might see something you missed.
Leave off the MMC and dimension them using the old stand-by, XY locations. Then, do TP RFS, no datums in the TP. THe deviations should be exactly the same (since you should already be aligned to ABC). Then do TP MMC on the feature ONLY, no datums, again, the deviations should be exactly the same. Then do TP~MMC WITH datums and see what you get.
Myself, I NEVER use datums in the TP since every version of Pcdmis comes with a different 'system' of using the datums in TP, and each time it changes, B&S/Wilcox/Hexagon tells us that the 'new' way it the right way and the 'old' way is the wrong way. Just simple align to teh datums used in the FCF and leave the datums OUT of the TP. If your process is so 'bad' that you need bonus from the datums, maybe you should change the process. Usually (at least, HERE) the available bonus that could be used from a datum is so small, it just isn't worth screwing around with the datums in the TP. I mean, my B/C datums will hardly ever give more than 0.002" bonus, and when the TP tolerance is 0.5mm at the smallest, 10% extra (MAYBE) isn't worth worring about.sigpic
I totally agree with Matt here, not that I normally don't, if you need just that bit more of tolerance, you are going to make bad parts. Unless the MMC is really needed on the feature, I don't normally use that either. The reason being, if you make good parts without the bonus, you have more leeway for your process to move, without making ANY bad parts. I am no production guru, but I think Matt has hit the nail on the head here.Jim Jewell
I'm on board with Matt as well. Especially doing PPAP layouts I never use MMC. I have some "discussions" with our tooling department at times but the way I see it, if a brand new tool needs MMC for a part to be in spec what will the part measure after several thousand hits and a few acknowledged misfeeds mixed in?
These *%#&!)% toolmakers get paid top money, EARN IT BY BUILDING A QUALITY TOOL. If we want something cobbled together that makes a marginal at best part we'll go off shore to get them.Perry
B&S Mistral
3.207 Beta on XP
Older'n dirt
Originally posted by Underspec View PostI have a part that looks like a can. It has holes on the sides at set angles from a datum hole (C) which is also on the side. I set [A] as the plane, [B] as the OD, create a line from B to C and rotate accordingly. On top of the part there are holes that are TP to A-B-C using MMC on the feature, -B-, and -C-. When I dimension TP using datums with MMC on the feature, -B-, and -C-, i get out of spec conditions. When I don't use -C- for MMC then it comes into spec. I figure I am safe not using -C- for MMC because I rotate basic to these holes on top anyway. Any ideas?
What you may have is that your C-datum size is out of tolerance. If one of your datums is out of tolerance, PC-DMIS will revert ALL datums back to RFS and calculate as if the MMC was not on C AND on B. Look at the size for C.
I know it is not popular to disagree with the Holy Hoedeman, but in this case I do. Even though what he professes makes perfect practical sense and I always initially evaluate my features the way he does it (that's the only way to understand what PC-DMIS exactly does), to me it does make sense to also evaluate the feature as it is listed on the print (which means with MMC on the datums). This is the way the engieer wants it, that's the way he gets it. I accept parts based on that call. Not on any of the previous calls.
Adding MMC to the datums does not always give a "small" bonus. I have had cases where the VC on the datums ligitimately DOUBLES or even tripples the tolerance on the feature to be evaluated. It all depends on how the datums are layed out.
Be aware that V4.1 does NOT properly evaluate multiple VCs on datums. If your datum has more than 1 VC, 4.1 adds them up. 4.2 has been corrected and it uses the most restrictive one. So if you have multiple VCs on your datums, you MUST upgrade to V42. No way around it. If you have a single VC on your datum, you're all set with 4.1.
Originally posted by Jan d. View PostYou know that you can only properly analyze MMC on datums (Virtual Condition or VC) when using the new XactMeasure GD&T? The lagacy can not handle that.
Jan.
Second, I stated that the most bonus that I would ever see is a couple thou (0.002") on my B&C datums. Automotive sheet metal does NOT give much tolerance on locator sizes. Typical tolerances are:
+0.05mm/-0.00mm
+0.025mm/-0.010mm
+/-0.050mm
These are the 3 that I see. Rarely do I see anything OTHER than those 3 toelrances, and I have NEVER seen one with as much as a total of 0.25mm. So, in MY case, the MMC on a datum is useless. Add to that the fact that 90%+ of the time, my B&C holes are on solid pins in a fixture with no way to measure them. 9% of the time I get a stab pin where I MIGHT be able to measure the hole, depending on stock thickness/net pad clearance. The other <1% is an iterative alignment. BUT, again, the size tolerance for these locators is RARELY over +/-0.05mm.
But, when trying to figure out WHY the TP is giving you the answers it is giving you, you go back to the basics, eliminate ALL the fancy extra's and see what you get, then add them back in, one at a time, until you see something different.
Also, another question (or two!)
1) Are you using surface sample hits? If so, HOW many?
2) Are you reporting TP PERP to CENTER LINE?
PERP to CENTER line will eliminate the SURFACE deviation when used with a surface sample hit and will give you a 'different' TP result than just printing the XYZ deviations for a hole that is NOT square to an axis. I always use PERP to CENTER LINE since I have to simulate a 'stab pin' being put in the hole.
Surface sample hits will change the 'major' axis deviation by including surface deviation in the result. A single sample hit will set the 'depth' for the circle touches, 3 or more will also change the 'nominal' vector of the touches to match the actual surface vector that the hole is in. When done with 3 or more, I do NOT know what it uses for PERP to CENTER LINE calcualtion, does it use the nominal vector OR the actual vector of the surface.sigpic
90% of my parts have a very flat plane for datum A and then 2 pin holes (B and C) that must be measured as cylinders since they are deep (compared to the diameter). I use the XactMeasure GD&T to calculate the perp from the cylinderical features to A. Most of my other features are also cylinders and flats that must be evaluated to the pin holes. I take regular vector points and circle features (construct a cylinder).
I tried many data sets and evaluted them in many ways. I am convinced that V4.1+ takes the VC on the datums into account properly.
Looks like I am just going to remove the MMC bonuses for now and just use RFS. I just upgraded from v4.1 and I am sure v4.2 is calculating differently. I don't remember seeing this problem with v4.1 when I wrote it.I used to be high on life but I built up a tolerance.
Hi Folks,
This is my first post here since the new forum, so here goes.
ONE machine with 3.7mr2 PH10T / TP20
06-06-2006, 02:51 PM -
by MFCguyis the total positional tolerance = Bonus- Dev.?
Our Bonuses are coming out huge b/c we are really **** close to the feature location,...-
10-18-2007, 01:18 PM -
by AuRules99.9% of our blueprints uses +/- tolerance to control feature locations. Now after running these part for 40 years, the engineers wants to convert to...
07-16-2008, 01:29 PM -
by rerun_livesWhen I try to Dimension a circle for true position and try to apply MMC from two other Datum features my True Position Deviation keeps coming up with...
05-26-2006, 11:33 AM -
Has anyone had problems with Xact Measure TP dims? I have various parts with MMC on the DF as well as the Datums. As may be expected the DF and the datums...
03-26-2008, 08:58 AM -
