We also use WF2.0. But this does not seem to work for me. Oh well, I have the direct Pro input feature now. I guess I must be happy.
What happens in my case is that complete surfaces or cuts are missing. It seems as if in the translation some of them just get skipped. I tried to figure out whether that was something that Pro does, but I got nowhere. Some models have this problem, some don't. It seems to get worse if the more parts are assembled to the part (like the fixture and all it's details).
Jan.
Stp Import from Pro/E
Running 3.7 MR2. Everything looks good to me. Is there a particular area that shows up bad for you?
Put the config file in the directory that you are
exporting the stp file to.
At least this works for me (Pro/E wildfire 2.0)
(see attached zip)Attached Files
Whow, tell me: how did you fix it? I'd like to know! What is the magic setting? Please post some more instructions! I have had the same problems.
Jan.
I have now solved the problem!
I tried a lot of different export configurations in pro/e
and found a setup that works.
Just imported both these models and there is no problems.
I use ProE daily and have found sometimes step works best and othertimes iges. I have always attributed this to a combination of things mainly the way the model is created and / or the selections that have been made when exporting to another format.
I am Running 3.7MR3 for info
Good luck
JonLast edited by jon_dav_uk; 05-09-2006, 10:59 PM.
Did you try exporting this as a igs file. sometimes that works when step doesn't . the nice thing about Pro E is it is so easy to alter the cad model origin to the way you have the part set up on the machine.
I had a similar problem. I am not much of a Pro/E jock, but something must get lost in translation.
I had to get the direct Pro/E import tool (File/Import/Pro_Engineer) from Wilcox. That did resolve all my issues.
Maybe there are ways around this in Pro-Engineer because some of my (always very large) models came in successfully through STEP, and some never worked. I have no idea why that would be. I had never any luck with the IGES translation. Again though, after I could import native Pro/E, all my model issues evaporated.
Sorry for not being more helpful....
Jan.
3.7 MR3
I just opened both files.
I didn't see any holes, except on both parts, a very small (possible) hole at the back of the oval slot.
I am running a different version than you however.
John
Hi all!
I have problems importing stp models created in
Pro Engineer.(missing surfaces)
I would be very grateful if someone running version 3.7
or higher could try importing the files.
In the attached zip archive there is 2 files created with
different settings.
I am running 3.5 MR2Attached FilesLast edited by wingardh; 05-08-2006, 09:22 PM.Tags: None
by sandypacificI am using an older version of PC-DMIS (4.2), and when importing UG (NX6) models I'm having difficulties with the models.
1. Some models...-
09-17-2014, 01:17 PM -
by quality2214I am currently using version 3.5 Maintenence release 1. I am attempting to import a solid model produced in Solidworks Version 7. It does not appear...
12-11-2006, 03:50 PM -
We are running PC-Dmis 2010 MR2. I am trying to import an IGES file into my program that is 82.1 MB. When I import it in it shows up as just a big black...
11-19-2012, 02:05 PM -
Any of you know the difference between STEP-AP203 and STEP-AP214 files? I got a file from a customer (IGES) that Pcdmis would NOT import, it would get...
10-09-2006, 02:02 PM -
by RCW52could anyone tell me the best files to use when importing?
i started using 'iges' files at first(as told by B&S) but of late been using 'step'...-
06-11-2008, 12:39 PM -
