Vectors
  • Vectors
    Hi all
    PCDIMS 3.7MR2 cad++
    How or can you have the vectors for IJK show up in the final dimensional report??
    Thanks
    Yes.
    When you create a dimension, click "on" the textual analysis.
    This will lengthen your report. You get another block of data showing the measured axis and the IJK values.
    John
    Lately, it occurs to me
    2017 R1 (Offline programming)
      When you go to dimension the feature (Feature Location). Check the V under Axes. V is for Vector.
        You could assign variables to each vector and use them to dimension a generic feature for example:
         MOVE/POINT,NORMAL,-2.5,8,4
                    ASSIGN/IVECT = 098_SURF.I
                    ASSIGN/JVECT = 098_SURF.J
                    ASSIGN/KVECT = 098_SURF.K
        VECTOR_POINT=GENERIC/POINT,DEPENDENT,RECT,$
                    NOM/XYZ,0,0,1,$
                    MEAS/XYZ,IVECT,JVECT,KVECT,$
                    NOM/IJK,0,0,1,$
                    MEAS/IJK,0,0,1
        DIM VECTORS= LOCATION OF POINT VECTOR_POINT  UNITS=IN ,$
        GRAPH=OFF  TEXT=OFF  MULT=10.00  OUTPUT=BOTH
        AX    MEAS      NOMINAL     +TOL       -TOL        DEV      OUTTOL
        X      0.0001     0.0000     0.0500     0.0500     0.0001     0.0000 ----#----
        Y     -0.0003     0.0000     0.0500     0.0500    -0.0003     0.0000 ----#----
        Z      1.0000     1.0000     0.0500     0.0500     0.0000     0.0000 ----#----
        END OF DIMENSION VECTORS
        Would dimension the I,J,K of a plane named 98_SURF.
        Craig
