When I loop a program with an offset and I cancel the program before it ends, the X,Y,Z in the auto features don't re-zero! Is there an automatic way of doing this?
Looping with offsets - aaw the pain...
Not sure exactly what your situation is but you may be able to use variable assignments of 0 (how ever many you need) before the loop starts. Use these assinments in the loop to set to zero what ever it is you need to be zero. Then increment them with each loop. Everytime you execute thr prg it will start with them at 0.
by WolfManI have not done this in a very long time, can someone suggest the best way to loop. I have 4 identical cylindrical parts that I want to measure in one...
08-09-2017, 10:49 AM -
by arockTrying to figure out this looping.... I got as far as taking the first feature of the alignment on the second part! Then it went way over in space and...
06-14-2018, 08:44 AM -
Good morning all I hope you are all having a good day, I have a program that contains a simple loop to check multiple pockets on a valve rotator body,...
01-13-2017, 04:37 AM -
by KingkrabSo I have 16 parts I need to measure in a 4 rows of 4 pattern. It's a simple 5 hole bolt pattern concentric to the I.D. Plane on the flange and level...
10-10-2014, 06:10 AM -
by JBELLI have searched with no luck for an answer. I am very new to looping and have some questions. Right now, I am doing a Man align then loop commands then...
11-04-2015, 02:58 PM -
