Custom Colors?
Custom Colors?
So I was lookin in the PC-Dmis directory on the puter today and I noticed three files. Here is the name of one. "NEW DEFAULT COLORS.CLR" I was wondering if this is a way to change the color scheme of PC-Dmis? If it is, does anyone know how to do it?
CMM Programmer
Jackson Michigan
Mistral 7.7.5
4.3MR2Tags: None
You 'load' those under one of the menus, but I can't remember where at the moment. It will allow you to load the 'old' defaults, the 'new' defaults and I think you can make a set of customer colors and save it as a user definded set that you can recall later when eithe Pcdmis or an operator messes it all up.
FOUND IT, it is under EDIT WINDOW COLORS, you can IMPORT, EXPORT color 'styles'. (SHIFT + F6)sigpic
by jkb_mcgI know I've discussed this before on here but I couldn't find it....
Does anyone have problems in 4.2mr1 with the dimension colors staying...-
08-18-2008, 02:24 PM -
by AJHVW93Is there a way to change the color of the text in the elogo.dat and logo.dat files? Its not in the edit window colors. Thanx
01-04-2008, 04:47 PM -
by AuRulesCan't remember due to the rumor of 33% of our work force being cut. Where do you change the color of the printouts. I does a red=out of tol. black=in...
01-12-2009, 07:57 AM -
by BOB PARSONSHas anyone ever seen the colors change by themselves, specifically I'm talking about the colors after the outtol column that show you the percentage of...
11-08-2006, 06:43 PM -
