Straightness
  • Straightness
    Hi. Could anybody instructs me how to measure a line to apply for Straightness dimension ?.
    I read in the Manual Referrence. It says the line for straightness should have 3 points minimum. Do I have to pick up 3 points for a line or pick up 3 single points, then construct a line ?
    Before comming up this question, I ve already tried it, the straightness result was 0.00. I wasnot sure it was right . I need a expert from this forum to give me a confident answer.
    Many thanks
    Straightness
    You can use both options. Either measure individual points and construct a line, or measure a line. The more points that you use the more accurate reading you will get. For your straightness of 0, there is the possibility you measured a line that was that straight. You could always test to make you your dimension is giving you an answer besides zero. Just measure your two hits on an actual straight line and a third off the line.
    28 Years, 8 Months, 0 weeks and 1 Days until retirement...
      YOU MUST also make sure you are in the correct workplane if you just go a measure a line. For instance, if you measure a line that is in reality (wht a concept) in the Z+ workplane, but you measure it in an X or Y workplane, it will report a straightness of zero since it was not done in the correct workplane. Workplane really effects your measurements in a case like this. IF the line is NOT in a workplane, you will need to measure the plane it lies in, then after you measure the line, change the parameter from WORKPLANE to FEATURE, then enter in the feature ID of the plane you measured.
        If he constucts it, should it be a 2d or a 3d line?
          Thanks you very much for your quick respond
            Good question! Are there any more? No? Class dismissed!
            Well, it might depend on what type of points he collected and where they are in relationship to datum planes and stuff like that. If you make a 3-D line, then your straightness will actually end up being a 3-D dimensional value, since the line is now 3-D. However, unless he IS in a workplane and CAN be in that workplane, he will not get good data constructing a 2-D line. You can not tell Pcdmis to construct a line in a 'feature plane' in the same way you can tell it to measure to that feature, like in my first post, you would have to make an alternative alignment to do that. Also, I am not sure if SNAP points will have an effect on this either.
            Personally, if I could be in a workplane, I would measure it as a line, if I had to construct a line, I would do it 2-D, but I would make an alternative alignment so I could construct IN a workplane.
              OO! OOO! I have a question Mr. Hoedeman! Aren't you going to assign any homework? I think you forgot to.
                Hahahahahahahhahahahahahahahhhahahahahahahhahahaha hahaaa
                OK, for tonight, I want to all to find out how many ounces in a 12 ounce can of beer actually come back out the other end when your body is done with it. Now, this may take some time, but I do NOT want you to just ignore this assignment! It may take many beers to get a good over-all average return, so I expect 3-page papers on the re-issuance of beer in the morning from EACH AND EVERY ONE OF YOU!
                  Personally, if I could be in a workplane, I would measure it as a line, if I had to construct a line, I would do it 2-D, but I would make an alternative alignment so I could construct IN a workplane.[/quote]
                  Teacher, Teacher, When you say an alternative alignment, are you refering to,f it is not in a normal X, Y Zworkplane?
                    Yes Paul, I am, if it is NOT in a normal workplane.
                      what type of an alignment?
                      iterative ,321 best fit
                      where is zero
                      mid line , end one or end 2
                      2d 3d
                      workplane
                      and its only monday
                        I would only create a LEVEL alignment for the construction, then create and dimension, then go back to the regular alignment, NO CAD=PART for the 'level' alignment.
                          I would measure 3 circles 2 ends 1 mid
                          create alignment
                          and apply MMC
                          Just to see the look on the engineers face
                          when I tell him its ok per MMC
                            But I don't drink canned beer. Bottles, sometimes they are 16 ounce. Is that OK teach?
                              How many shots of beer is that ?
