Is there such a thing as an implied 90 deg angles or implied perpendicularity and flatness using ASME Y14.5M-1994 standard? And can you tell me where to find info on this topic in the standard?
Implied dimensions
This is what I found for implied 90 in the ANSI Y14.5M-1982.
2.1.1.2 - Unless otherwise specified, where a general tolerance note on the drawing includes angular tolerances, it applies to features shown at specified angles and at implied 90 degree angles.
I was alway told that if the angle was not called out it was a implied 90 degree angle.
As I understand it (Kevin correct me if I am wrong), a true position has an implied perpendicularity in it. For example if you have a plate with one hole drilled in it and the top surface is -A-, the front is -B- and the side is -C-, then the true position of the hole called out to ABC has a perpendicularity to -A- included.sigpicYou're just jealous the voices talk to me.
The hole's axis is bounded by the depth of the feature. The entire feature. So yes, in a way position does control the orientation of the feature. So, the entire axis of the feature must lie inside a cylindrical (if that is what it is) tolerance zone bounded by the length of the feature. A good way to think of this is: Drop a pencil in a coffee mug (unempty of course) And notice how the pencil (axis) lie's in the mug. FYI...0.02
KevRFS Means Really Fussy Stuff
90 degrees always unless otherwisw specified.
Flatness is another issue it is the the distance for your tolerance between two parralell planes unless othewise specified.
Note otherwise specified may be in workmanship notes on a drawing. It does not need to be on the actual drawing if it states some sort of workmanship spec. this can also apply to perpendicularity.Tolerance challenged ... Living in the world of unseen lines.
by inspector212I've searched the forum back to July for answers with no success.
I liked the True/Complement option for angles but they "enhanced"...-
12-19-2007, 03:30 PM -
by kcassadayI'm having a problem understanding how can you call out the position of a hole to the plane in which it resides. For instance, Datum A is the surface...
02-28-2018, 09:39 AM -
by GEO3DI am currently programming a job from drawing with a hole with no true position specified, it has boxed dimensions which would imply a true position....
02-23-2016, 12:13 PM -
by orionRefer to attachment of a component. having trouble obtaining the result. I need to check the compound angles 30° and 19°. Please advise on best way...
06-14-2010, 04:37 AM -
by misaelI haven't really dealt with hole patterns so how do I dimension these angles on cmm report? and what tolerance do I use for all basic dimensions? Any...
02-03-2017, 08:39 AM -
