I have a fixture to inspect that checks profile of a stamped part. The profile of the fixture is offset from the nominal by 3mm so that a go/no-go feeler can be used to check profile. I do not have CAD data for the fixture, but I do for the part. What I would like to do is import the CAD, create vector points, offset them by 3mm along the vector and reverse the vector. this will create nominal points to check the fixture to. Is this possible? 3.5mr2
TIA
TIA
