round slot location
  • round slot location
    Does anyone know a way to report the radius point locations after measuring a round slot? I like PCDMIS's system of report the slot center. The engineers want the location of the points at each end.
    This information source is so cool!
    Thanks for all the help.
    David Kick
    Pick up the ends of the slot as circles and report them. If you need both the slot and the ends, you can construct the slot from the two circles.
    Bill
      David Kick
      try checking the slot as two circles and report the centers of the circles... that should give you exactly what you need.
      XYZ_IJK
      pc-dmis 2012 mr1, 2013mr1
      calypso 5.4 sp1
        SLT2       =AUTO/ROUND SLOT,SHOWALLPARAMS = YES,SHOWHITS = NO
                    THEO/72.076,-439.607,522.199,0.1320065,0.2690133,0.9540472,9.2,15.22,-0.6527641,0.7479054,-0.1205678
                    ACTL/71.9539,-439.4797,522.8106,0.1275026,0.266694,0.9553101,9.3968,15.4325,-0.6560728,0.7450277,-0.1204252
                    TARG/72.076,-439.607,522.199,0.1320065,0.2690133,0.9540472,-0.6527641,0.7479054,-0.1205678
                    THEO_THICKNESS = 0,RECT,IN,ONERROR = NO,$
                    AUTO MOVE = BOTH,DISTANCE = 25.4,RMEAS = None,None,None,$
                    READ POS = NO,FIND HOLE = DISABLED,REMEASURE = NO,$
                    INIT = 3,PERM = 3,SPACER = 3,DEPTH = 2,HITS = 10,MEAS ANGLE = 80
                    VOID DETECT = NO,$
        LINE1      =FEAT/LINE,RECT,UNBND
                    THEO/72.076,-439.607,522.199,-0.6527641,0.7479054,-0.1205678
                    ACTL/71.9539,-439.4797,522.8106,-0.6560728,0.7450277,-0.1204252
                    CONSTR/LINE,CAST,SLT2,15.22,DEPENDENT
        LINE2      =FEAT/LINE,RECT,UNBND
                    THEO/62.1409,-428.2239,520.364,0.6527641,-0.7479054,0.1205678
                    ACTL/61.9684,-428.1404,520.9777,0.6560728,-0.7450277,0.1204252
                    CONSTR/LINE,REV,LINE1,15.22
                    ASSIGN/T1 = DELTA(SLT2.TXYZ,LINE1.TIJK,(SLT2.LENGTH/2-SLT2.DIAM/2))
                    ASSIGN/T2 = DELTA(SLT2.TXYZ,LINE2.TIJK,(SLT2.LENGTH/2-SLT2.DIAM/2))
                    ASSIGN/A12 = DELTA(SLT2.XYZ,LINE1.IJK,(SLT2.LENGTH/2-SLT2.DIAM/2))
                    ASSIGN/A2 = DELTA(SLT2.XYZ,LINE2.IJK,(SLT2.LENGTH/2-SLT2.DIAM/2))
        SLT2MID    =FEAT/POINT,RECT
                    CONSTR/POINT,CAST,SLT2
        SLT2P1     =GENERIC/POINT,DEPENDENT,RECT,$
                    NOM/XYZ,T1.X,T1.Y,T1.Z,$
                    MEAS/XYZ,A12.X,A12.Y,A12.Z,$
                    NOM/IJK,0,0,1,$
                    MEAS/IJK,0,0,1
        SLT2P2     =GENERIC/POINT,DEPENDENT,RECT,$
                    NOM/XYZ,T2.X,T2.Y,T2.Z,$
                    MEAS/XYZ,A2.X,A2.Y,A2.Z,$
                    NOM/IJK,0,0,1,$
                    MEAS/IJK,0,0,1
        HTH
          David Kick
          Use GENERIC points like this:
          CDATUM would be the name of the slot you measured:
          P001       =GENERIC/POINT,DEPENDENT,RECT,$
                      NOM/XYZ,0,0,0,$
                      MEAS/XYZ,CDATUM.HIT[1].X,CDATUM.HIT[1].Y,CDATUM.HIT[1].Z,$
                      NOM/IJK,0,0,1,$
                      MEAS/IJK,0,0,1
          By the way, how is your IT doing?
            Thank you. The autoslot seems to give better results than the two half circles method, but if that is what the engineers want, that is what they will get.
                          NOM/XYZ,0,0,0,$
                          NOM/IJK,0,0,1,$
                          MEAS/IJK,0,0,1
              I dont understand what your doing here.......Why would you report your first hit?? Please explain wise one...
                David Kick
                Wasn't sure if he wanted the POINTS for the radius or the center of the radius. This will make a point of the individual hits, covering the possibility no one else was addressing.
                AND, if he likes the 'slot' routine better than the 2 half circles, he can do the slot, THEN construct circles from the individual hits at each end if he wants the CP of the radius.
                  Oh i see says the grasshopper.......
                  Gotcha! Thanks for the clarification.
                    No, it's:
                    "I see" said the blind man and he picked up his hammer and saw......
                      Matt,
                      I like this approach best, any way the data is analyzed it will all "jive". An auto slot for the center and then 2 probed circles leaves room for minute disagreements between the data sets and perhaps then questions.
                      TK
                      sigpicHave a homebrew
                        Originally posted by tking View Post
                        Matt,
                        TK
                        Good point, I never thought of it that way. Not bad, grasshopper, not bad! Now, can you ****** the pebble from my hand?
                          Well, I don't mind picking your brain, hoss, but the "pebbles" are not on my agenda.
                          Thanks, again,
                          TK
