There is a flatness callout for a O_Ring, checks are done every 60 degrees, he want the flatness for points in a line. Which is the range. I have never used what if statments, but is there a way to check this? If you need more info please asked.
flatness of a line
Originally posted by steveThe only form a line has is straightness. You may have to change workplanes and check straightness of a line to get the flatness you are looking for.
Rebel, correct you need a plane to check flatness, and it has to be more than 4 points.
bw_bob it not the rubber o-ring, its the area the ring is going to be placed.
steve"what?" Paul What?
Thanks all.sigpicSummer Time. Gotta Love it!
Originally posted by Paul SarrachSteve Thankyou. I have never used straitness before either. And I been doing this a long time.
Thanks all.<internet bumper sticker goes here>
Originally posted by Rich PHey Paul
We mnaufacture a part that has an O-Ring Groove machined in it
we have a groove diameter and slot width called out on this part
If they are looking for form deviation shouldn't it be roundness or cylindricity?sigpicSummer Time. Gotta Love it!
Paul, you really should limit the drinking until at least after noon.... Your posts seem like a cell phone call with a bad connection.
How many points are you taking on each cross section?
For each cross section you should rotate the work plane to that view so that the straightness is "viewed" correctly. IE, if the oring seat is in the XY plane and you want the cross sectional straighness of the section that cut through the plane at the center, your view should be ZX or YPLUS. other wise the straighness wont be right
Ok here it is, a pic of the oring SEAT open in paint and make alittle larger to read fine print
Craiger ok ok ok oring seat, Whatever!!!!I am Squirrelly, not an engineer, but after talking to them I get even more confused, than I normally am, and its even harder to put in words what they cannot even say????
What?
. So I really need all this booze before noon, just to keep my self from hurting them
Last edited by Paul Sarrach; 08-25-2006, 07:25 AM.sigpicSummer Time. Gotta Love it!
by ptedrumTypically how does one go about doing a flatness check of a surface with PC DMIS?
07-31-2007, 10:34 AM -
by Don-ARIHow accurate is a flatness measurement taken on a surface that I had to level to?
With what I have available using open setup, I am really measuring...-
09-10-2010, 12:10 PM -
by gsepanGood Morning all,
My question is regarding a flatness callout on a print I'm working to. The callout wants to hold a flatness of 1.5mm...-
08-28-2006, 10:47 AM -
I have 'n' number of points. Pi = (Xi, Yi, Zi) where i = 1, 2, 3 ... n
I fit a least square plane ax + by + cz = d and calculated distance...-
08-21-2015, 09:47 PM -
by grandpaal56I have a part with a surface that is about 800mm long by 200mm wide the print is calling for a flatness overall on the surface of .05mm, and a zonal flatness...
03-08-2011, 09:22 AM -
