I have a part program that i have ran six times. the first measured a diminsion diameter at 2.0062" the second at 2.0055" the third at 2.0047" fourth fifth and sixth at 2.0048" and 2.0049". Same part same program no climate variations or movement of the part. program was ran back to back. i wiped the part off inbetween runs to ensure no dust had settled. the diminsion has a .001" tolerance and is a semicircle so a gage pin wont work. i use a manual alignment and dcc alignment. why would the diminsion be different on the first three and then repeat on the last three. nothing has changed. any help would be appreciated. also would after the measurement repeating the alignment and remeasuring in one program help to check for repeatability.
thanks.
thanks.
