System Name Utility
  • System Name Utility
    A question came up yesterday, I thought I'd share the solution. A customer has several systems with PC-DMIS, and runs the same programs on all. One of these has a network issue, which requires some operator intervention before proceeding. They wanted a way to alert the operator, but only on this particular system. We came up with a short exercise which identified the name of the system, and if it were the one in question, displayed a message to the operator. Here is how we did it.
    We wrote a short DOS batch file with the following command -
    IPCONFIG /ALL > JUNK.TXT
    and we called this file "GET_NAME.BAT" and placed it in the PC-DMIS install folder. Then we added these commands to the top of the program (note that the 1st line is 'wrapped') -
    EXTERNALCOMMAND/NO_DISPLAY, WAIT ; C:\PCDMISW_V37B\GET_NAME.BAT
    FPTR =FILE/OPEN,JUNK.TXT,READ
    V1 =FILE/READLINE,FPTR,{T1}
    V2 =FILE/READLINE,FPTR,{T2}
    V3 =FILE/READLINE,FPTR,{T3}
    V4 =FILE/READLINE,FPTR,{T4}
    COMMENT/OPER,NO,T4
    ASSIGN/V5 = INDEX(T4,"CMM2")
    COMMENT/OPER,NO,V5
    IF/V5
    COMMENT/OPER,NO,Check the network please
    END_IF/
    The program runs the batch file, which displays a load of information and re-directs the output into a text file called "JUNK.TXT". The only thing we want out of this text file is on the 4th line, se we read and ignore the 1st 3 lines. On the 4th line, we read it and then check for the existence of the string "CMM2". This 4th line might have had something like the following -
    Host Name . . . . . . . . . . . . : Desktop_CMM2PC_AJD
    but we only need to determine that it contains any unique character set which will identify it as the one we are searching for.
    With this, we were able to make use of an EXTERNAL command and a few FILE I/O commands to achieve what this customer wanted. I doubt that many people will be able to use this utility as-is, but I decided to post it here as an example to stir people into thinking about what else they can write to make their jobs a little easier.
    DANG!
      If all you want is the 4th line of text you should be able to do a file/readline,fptr four times. You do not need to assign a variable to the first three, only the fourth. You could also loop it. Just my $0.02
        Not the only way. . . .
        Those are good points. I'm sure there are more efficient ways to do this. We had just thrown it together quickly to solve this guys problem, and some of the stuff you see in is remnant from our debugging/devlopment efforts. We were displaying each line as we read it to make sure we got the right line.
        I was originally tempted to start writing a VB program, but then I figured that PC-DMIS should be able to handle it, so I gave it a shot and it worked fine.
          Absolutely, nice job. There is always more than one way to skin a cat.
            Shows what's important here
            Monty Python - 52 and counting
            Don - 4, 1 of which is my own
            We know what people consider valuable on this board
              Hers one more Don, because I like you. Never mind 3 of them are me.
                Thanks
                I think I get negative points for having a guy picking his nose in response to my post.
                  Sheez you guys are cynical. I didn't post anything because its' out of my league to respond.
                  But, I did make the thread printable and put it into my DMIS FORUM scrap book right next to my directions for the south african shim sham sand dance(Mel Brooks History of the world I believe, Gregory Hines as the slave?).
                  Sorru all the good Monty Python stuff was used.
                    That avitar is evil. Eeeeeeeeeeeeeeee-vile. I love it! I absolutely love it! Now everyone say "Thank you Tom Miller" for turning us on to the animation thing (what a great idea Tom, what would I be without you?).
                      Thank you. And "Thank You Tom Miller!!".
                        Get them collections together ....b4 trail runs out
                          I would of gotten the IT dept. to fix the network issue. But that solution sounds great! Good job.
                            Just a post to get one in too!~
                            Gabriel
                              Gabriel
                              And he is a non-nose-picker too!
