I am using version 3.2061 on two different machines. I use old style report mode on both machines. One machine the reports deviation symbol gives an "#" only on in tolerance dimensions. The other gives an "---------#-------" symbol. My question is how do I change the symbol of the second to perform like the first.
Reports
There is a setting for dimension colors. In the same section, you can tell it how many tolerance division zones there are, which controls howmany ---#--- you get in the report. Not exactly sure where it will be in your version, but in mine it is EDIT ~ GRAPHICS DISPLAY WINDOW ~ DIMENSION COLOR.sigpic
Ver. 2011 MR1. Legacy reports, text version. For as long as I can think the far right column of the dimension(dashes with # showing approx. deviation...
05-15-2015, 10:49 AM -
by JenWaschAll of my other reports come out with 5 bars to get a better idea with just a glance whether an item needs to be reviewed further.
This one is...-
02-16-2015, 12:29 PM -
Running PC-DMIS 2013 MR1
Hello! The boss wants a pretty colored report for dimensions. Essentially, if the dimension is in, green for good,...-
07-27-2017, 12:44 PM -
by wowieHello,
I would like to find out how I can change the color of the deviation bars that appear on the reports. Currently it comes out in...-
04-26-2014, 02:34 PM -
I have a small Annoyance.
The graph colors on my report are colored, and Red is the chosen color for dims that are closest to nominal.
That...-
02-05-2013, 05:03 AM -
