it is while I have issue with my PH9 .
when it is changing orientation, some times it makes Wierd noise ( Crack) inside the ball shape, and it moves to wrong Orientation, some times the Red light on Handy controlel goes On, some times does not.
some times it trys to correct the PH orientation by trying and making more noises, finally it fails and PH Release the Gear ( the Tip get loose and moves downward, like you have put pressure on the TP).
What do you think? I belive that is wrong with PH9 isnt it?
tahnx
tahnx
