Newbie with a problem
  • Newbie with a problem
    Red IF atIF/MEAS_opt>1
    What does this mean
    If any part of it is RED, then there is either a SYNTAX error OR a bad variable. Basically, it means you done did something wrong but what is wrong will depend on exactly what you are trying to do.
      Syntax Error...for example:
      IF ONERROR goto Label1
      You will get a Label1if there is no Label called "Label1"
        This is a summary;
        END_IF/
        IF/MEAS_OPT>1
        COMMENT/REPT,"CMM OPERATOR: " + OPER
        ,"CMM NUMBER: " + CMM
        ,"MACHINING CENTER: "+ MACH
        ,"SPINDLE NUMBER: " + SPINDLE
          This may be a dumb questin but where is your end if?
