I have an engine block in which crank#5 and crank#1 should be align on its centers of the cranks (cranks#1 is 23"inches away from cranks#5). I'm getting .3365 offset and cannot understand what I'm missing. The block is a master block so it should be right and on centers. Any ideas would be helpful.
Thanks
A0 =ALIGNMENT/START,RECALL:STARTUP, LIST= YES
ALIGNMENT/LEVEL,XPLUS,PLN1
ALIGNMENT/TRANS,XAXIS,PNT1
ALIGNMENT/TRANS,YAXIS,PNT1
ALIGNMENT/TRANS,ZAXIS,PNT1
ALIGNMENT/ROTATE_CIRCLE,YPLUS,TO,PNT1,AND,PNT3,ABOUT,XPLUS
ALIGNMENT/ROTATE_CIRCLE,ZPLUS,TO,PNT1,AND,PNT2,ABOUT,XPLUS
ALIGNMENT/END
Thanks
ALIGNMENT/END
