Does anyone know the math behind the position calulation with this option turned on? I have a customer that wants to use it since it makes the postion significantly better - but they need to be able to justify/explain it to their customer and I don't know what's going on there. Clearly it's not just the square root of the the sums, etc.
Deviation perp to centerline
What it does is it 'constructs' a plane, perpendicular to the nominal VECTOR line of the feature being measured, through the actual measured feature, then calculates from the actual measured position to the intersection of the nominal vector line and the constructed plane. This gives the position of the feature to nominals, but 'compensates' for the deviation of the surface and leaves it out of the calculation. It is pretty much a 'required' option for checking the position of holes in sheet metal where the surface is not square to body line (vectors of 0,0,1 or 0,0,-1 or 1,0,0 or -1,0,0 or 0,1,0 or 0,-1,0). It simulates the use of a stab pin to check the hole.sigpic
This took a long time to get right
This is to calculate 2D true position (TP based error perpendicular to the centerline).Attached Files28 Years, 8 Months, 0 weeks and 1 Days until retirement...
by cvollmerHow would I report the Position of the circled feature in the print using xact measure? I am running 2012mr1.
Do I use planer zone? Do...-
10-15-2013, 08:25 AM -
by dragonbladeENG told me that with their True position call out they are concerned about the perpendicularity of these 4 holes to to -C-, as well as location.
01-26-2010, 09:25 AM -
Could someone please explain what a T-Value really is. I have never work with sheet metal axis before.
I think it is what i want but not...-
07-06-2007, 01:22 PM -
by WINDRIDERwhat is best practice on TP? perp to center? and how do I use only 2 axis?
3.7 MR3
thanks-
05-23-2007, 10:30 PM -
by Bob PierceWhen dimensioning TP of a 2D hole to datums ABC, the hole being normal to Z, is the Z location being used in the calculation?
07-12-2007, 09:17 AM -
