Can you please tell me how High Point Plane works? I mean what happened behind the command when we select several points and use this Plane construction?
I constructed a high point plane from 32 hits. 8 hits are higher than the plane. I calculated a tangent plane with Excel that give better results......
Currently am running PC-DMIS CAD++ 2016.0. I have probed a plane but would like to construct a plane based on the high points; as if it was sitting on...
