Have saved statistics using SPC Database but cannot transfer these to the datapage so that I can create report i.e graphs etc. any suggestions would be well recieved.
As far as I know, Datapage has to be set -up to pull in the data as you are running the parts. You can manually enter data also, but it is time consuming and really not cost effective
There shouldn't be any setup required to use Datapage with Pcdmis, other than inserting the stat command in the Pcdmis program, WITH the correct path to the location of the database. The database MUST be created first, however, there will be a 'new' one there when you install Datapage. It will be C:\DATAPAGE\PART or whatever drive you install Datapage on, mine happens to be on G.
thanks guys, problem was the XSTATS11.tmp file. Needs to be deleted before data base can be updated
My pal wrote a batch file to delte theis file from the desktop. I thought maybe someone would know how we can get that batch file to run at the end of the program after the stats command.
Just started having this problem yesterday (Mon 7/25). Datapage is not transferring data from xstats11.tmp. I can open xstats11 and see the data with...
Is there a certain release of PC-DMIS that has to be used with Datapage +, I am running version 3.7mr3. No class in my area until April and I am having...
I have to start using datapage with no training on it. Can someone give me a quick run through of exactly what it is. How does the data get from the CMM...
