I am running 4.1 and I would like to change the way the text looks in the "text only report" for the comments above each dimension. Currently the display is green but I would like to make it dark blue.
Edit comments in Text report
You should be able to do this by changing the color scheme used by your TextReportObject.
- Access the Report template you want to modify inside the Report Template editor (remember to turn off the read-only protection if modifying a standard template).
- Right-click on the TextReportObject and from the Properties dialog, choose Colors.
- Make your changes, save the template, and then reload it into the Report window.
Jared Hess - Techwriter @ WAI
by Lab_rattGot a problem I can't seem to fix - Runout shows on the report as a pale green, when printed you can't see it. How do I make the type color default to...
12-30-2008, 10:04 AM -
by KaSaBiSI can edit the reports dim color in its default state but when I right click edit object in the report window and select use text mode dimension only"...
07-07-2009, 04:14 PM -
by CMMPGMRWhere do I change the font colors for the text reporting in report window?
Text color is light green now. OT does shows red though.
PCDMIS...-
05-31-2007, 04:07 PM -
by racerx00Hopefully I can explain this right. In the default ppap template that comes with pc-dmis the fields at the top with text like, supplier, part name, inspection...
03-20-2008, 07:56 AM -
by hammerver 4.1 how do I change the text print color. In mr3 I have the text as black unless out of tolerance then red I would like to have 4.1 the same
10-12-2006, 08:38 AM -
