Just a heads up to everyone that uses edgepoints. As you can see in the attachment I have two identical points, edgepoints without sample hits, the only difference is the surface vector which should be irrelevant, but look at the actual Z value, it comps to the wrong side of the 2mm styli if I use a -1 I vector. It took me a couple of hours to find,hope it helps someone out in the future.
Bad EDGE Point Comp
Question:
Did you use a paste w/pattern to get the second point? I found in V3.5 (haven't tried in V3/7 yet) that when mirroring edge points, all kinds of problems crop up. The biggest one was that the surface vector didn't mirror even though it ran 'as if it did', but then the results were totally whacked and messed up. I found this on a part shaped like a bowl that had 8 notches in the edge. I used paster w/ pattern to get all 8 notches, but then no matter how I indexed the part, the results were exactly the same for the '12 o'clock' notch, no matter which notch I used as 'master' (as well as the other 6 'patterened' notches). I ended up having to delete the 'patterned' notches and checking them using alignment rotations and NO paste w/ pattern.sigpic
Originally posted by Matthew D. HoedemanQuestion:
Did you use a paste w/pattern to get the second point? I found in V3.5 (haven't tried in V3/7 yet) that when mirroring edge points, all kinds of problems crop up. The biggest one was that the surface vector didn't mirror even though it ran 'as if it did', but then the results were totally whacked and messed up. I found this on a part shaped like a bowl that had 8 notches in the edge. I used paster w/ pattern to get all 8 notches, but then no matter how I indexed the part, the results were exactly the same for the '12 o'clock' notch, no matter which notch I used as 'master' (as well as the other 6 'patterened' notches). I ended up having to delete the 'patterned' notches and checking them using alignment rotations and NO paste w/ pattern.James Temmen
How would that run? I see you have 0 initial and 0 permanent sample points. If you run an edge point with sample points and a flipped surface vector it will crash into the part, since it would be trying to measure from the inside. I R corn fused.
JaimesigpicYou're just jealous the voices talk to me.
No, the effect of the wrong surface vector would be to make the automove go to the wrong direction (down and left instead of up and left, for example) as well as the sample hit would be on the wrong side, the tip will still try to hit the edge point from the same direction.
Are those measured deviations or is it changing the 'actual' when you change the surface vector? Also, are you changing the surface vector in the edit window or are you doing an F9 on the feature? That is/was/has been a bug-a-boo with edge points for some time now as well, it won't change everything correctly if you do it in the edit window instead of F9. It will LOOK as though it did, but NOT!Last edited by Matthew D. Hoedeman; 04-27-2006, 01:56 PM.sigpic
I don't use sample hits because I don't need them for this hit. I only need to check the EDGE of the part. Thats why I didn't care what the surface vector was as long as it was in an X direction. It "shouldn't" have affected the reading,James Temmen
by BSmithCould someone with a little spare time (lol) explain the differences between a vector, surface, and edge points in simple terms. I totally understand...
04-22-2015, 12:03 PM -
by Guesta fixture shop gave us a pc-dmis cmm report with both T and S values reported, now everyone and their brother wants to know what the S-Value means vs....
10-12-2006, 08:19 AM -
Well, I would post this in the TIPS & DESCRIPTIONS section, but there isn't one (yet?).
SNAP POINTS:
1) Not a great...-
10-04-2006, 08:38 AM -
by rangerboat72Is there a way to get the T-value for Edge Points & Surface Points? I like using these features for several reasons but seem unable to use them for...
10-09-2006, 07:48 AM -
Well, I would post this in the TIPS & DESCRIPTIONS section, but there isn't one (yet?). I have put this here in the CODE section since it will not...
Channel: PC-DMIS Code Samples
10-16-2006, 08:44 AM -
